주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2201 질문 전체 보기
질문 마감됨
I cant restore my iPhone help!
when i try to connect my iphone to itunes to restore it like apple help told me to it wouldnt work and it said "sorry cant connect to itunes there was an error with your connection" so i checked my connection and it was fine so i did it again and again and it kept saying the same thing over and over again. I NEED HELP NOW!!!! please
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
f you need to restore the iPhone to its original state the process requires iTunes. This can be useful for troubleshooting to see if a problem is hardware or software related. The process can also reset an iPhone for resale, wiping all personal data from the device.
Should you suspect a hardware issue with your iOS device, Apple will normally recommend a complete restore to see if this clears up the problem. You can save time when you go to the Apple store by trying a complete restore first. Restoring will update your iPhone firmware to the latest version.
If your iPhone is booting to a black screen you need to follow additional steps before restoring your iPhone. See these additional instructions by clicking here.
1. Connect your iPhone to the computer and open iTunes.
2. Make sure your iPhone is selected from the left menu in iTunes.
3. Click the Restore button in the center of the iTunes Summary tab.
4. You can choose to Back Up the contents of your iPhone to the computer.
5. iTunes will ask if you're ready to Restore the iPhone, this will wipe all of your data and settings from the device. Click Restore.
6. iTunes will download, prepare and restore the software on your iPhone. Do not unplug the iPhone from the computer during this process!
7. When finished, iTunes will ask if you want to restore from backup. Choose "Set up as a new iPhone" to start fresh with factory settings.
8. Enter a name for your iPhone and the process is complete.
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
Try holding home and power button for about 10 sec when the screen goes of let power button go and hold home till a cable shows up on screen then try restoring with itunes !
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 5
전체 시간: 101
