주요 콘텐츠로 건너뛰기
모델 A1297 / 2.66, 2.8, 2.93, 또는 3.06 GHz Core 2 Duo 프로세서
1006 질문 전체 보기
Bad logic board. does that mean cpu is dead/ needs replacing?
I was told by a tech that my Macbook Pro is not working as the logic board is bad and needs to be replaced. They are asking $1000 for the job. I see replacement logic boards for a few hundred on ebay. Question - can the cpu be swapped or is it permanent fixed to the board thus I need a new i7 as well?
i am in NYC ... any help or direction would be appreciated.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
I would go to the Apple Store and ask them for the flat rate repair for your system. I must warn you time is running out as Apple will soon stop repairing this model so don't delay! If I remember its around $450 so its a lot cheaper!
As to the CPU: Sadly, its soldered to the logic board (not replaceable).
Depending on which model you have in this series, it could have a high resale value (working) in case you are leaning to a newer system.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Actual cost is $357from an Apple depot repair including shipping and tax @ 8.25% in Texas
댓글 달기
귀하의 답변을 추가하세요
tony Vas 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 163
