주요 콘텐츠로 건너뛰기
2009년 중반기 모델 A1278 / 2.26 or 2.53 GHz Core 2 Duo 프로세서 EMC 2326
745 질문 전체 보기
Will only turn on using smc boot method
When i plug a known working magsafe in nothing will happen no lights or charging and when i press power button it will turn on for a couple of seconds then shut down... I can only turn on the mac using the hold down power button and connect magsafe method and it turns on with fans at full speed and then it works... The battery has the X over it and no charging etc... Ive tried smc reset but still the same.. I need some help to find or fix the problem
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개
After using the SMC bypass method to boot, check that the left Shift Control and Option keys actually work (the SMC may not be reset if one of them is defective)
What color is the X, red or black?
have the same problem X is black
댓글 달기
답변 1개
선택된 답변
Something in your logic board is dead, probably a charging circuit component, that's why it turns on bypassing the smc but not otherwise. Unless you have the necessary technical skills to troubleshoot a logic board at component level you'll need a skillful technician.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
richard martin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 727
