주요 콘텐츠로 건너뛰기
Electrohome USB charging alarm clock radio with time projection. Identification model number: EAAC475.
Time is ahead by 8 minutes
The time is off (ahead by 8 minutes) has gotten there gradually since purchased - it was fine when I first got it about 2 years ago. I am not able to figure out how to reset it. When there is a time change (Spring & Fall), it does adjust by an hour, but still wrong by same number of minutes.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
That is normal behavior for most clocks. The time accuracy is usually +- 1sec/month, or something like that. To set the time follow the instructions described in this photo.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
tried the buttons like you're supposed to.. managed to put the clock back one hour.. can't fix it :(
댓글 달기
FIXED!
Note: power off, remove 3V battery, power on, reset year/month/day/12hr(am/pm)/hour/minute, replace 3V battery
Note: The translated manual is unclear or at least NOT 100% correct, I did not find DST or time zone
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Estelle 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 2,428
