I cannot get the charger into the slot
I cannot get the home charger into the slot - it will not go in
좋은 질문 입니까?
좋은 질문 입니까?
Check for damage to the port and to the charger look for bent parts or dirt in the port or lint in the port
해당 답변은 도움이 되었습니까?
the port looks like bent parts, what do I do? I had not taken out the service agreement with Walmart; they said the port needs replaced and to take it to a pc repairman. It is only 6 mos. old and I thought I should have gotten better service than that. Don't they have a year's warranty?
A bent port wont be covered by warrenty its considered damaged by owner The charge port is fixable yourself its time consuming but if you take your time very doable
Samsung Galaxy S6 Daughterboard Replacement
this is a how to guild
http://www.eddogo.com/charger-charging-d...
Here's a SM-G920F version of the charger port. Make sure you have the correct model number of the charging port or else you will run into charging and mobile network / service provider signal issues.
excellent tweezers saved the day. grass seedsfrom weeding and whiskers from my sink looked like dead bugs.
sewing needle worked at first, but the tweezers really pulled out the big stuff.get a better case with a cover for that spot.
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 4
30일 전: 11
전체 시간: 21,291
댓글 1개
I bought 2 new 10 inch Lenovo tablets from best buy, and one of he tables pots was very difficult to plug, and now I can see that it looks like the pins are damaged. Do I have any recourse for these. I have had the tablets 10 days.
Steve Hernandez 의
