주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
Battery % doesn't change. Need help to identify Components!
I have a very strange fault with a couple of iPhones. I regularly replace the rear housing of iPhones, I am very careful with the replacement of screws (correct screws in correct positions and not tightened excessively). I have successfully completed this over 50 times and consider myself fairly competent in doing so.
However, I have come across something which is very bizarre and has happened on three separate occasions now. Once I turn the iPhone on to test it the phone will blue screen and restart itself two or three times at random. Once this has happened the phone will function perfectly except for the battery % display will not change. Obviously this causes the user to not be able to track when it needs charging. The phone will run out of battery and the process will happen again.
It must be something I am doing to the phone, I am not overly fussed on finding a fix. Just a reason why this is occurring and how I can prevent it happening again in the future!.
Thanks in advance,
Update (03/31/2016)
I have done some more research and believe that the issue may be an "FL 11 capacitor" could anyone confirm this and give me some info about what it does exactly and where I can source one to try and fix the issue?
Update (04/01/2016)
So I have had a look at the logic Board under a microscope and have found that some capacitors have been knocked off when removing the battery. I think the one on the far left is a "FL 11 inductor" but I am not sure what the other two are. Could someone tell me what they are?
Good Logic Board :
Damaged Logic Board :
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 2개
Hi, I had not seen that. Have had a look over and has confirmed my theory that I may have accidentally damaged the"FL11 is a 120ohm 210mA inductor". If someone could confirm this it would be ideal.
댓글 달기
답변 2개
선택된 답변
Chris from right to left:
FL11 is a 120ohm 210mA inductor in a 1005 package
C279 is a 56pf 16V 5% capacitor in a 1005 package
C23 is a 56pf 16V 5% capacitor in a 1005 package as well
해당 답변은 도움이 되었습니까?
점수 4
댓글 4개:
Hi I'm Felipe Zuluaga and I go to Tray to speak in english... i have exactly too problem but i have a the boar that change the components, trying to change I lost C23 and FL11, can remplace the component this with other capacitor an inductor?
Felipe Zuluaga why not replace it with the right components? You do want to change a capcitor for a capacitor and inductor for inductor. You are not thinking about changing a capacitor for an inductor?
The capacitor does the opposite of what an inductor does. If you do that the battery circuit will not work.
I go to change the components, but I have a problem try to soldering. What kind should I use Soldering, wire or liquid? And what kind of point of the soldering iron?
댓글 달기
Hi, I have almost the same problem, but the FL11’s pad is missing. How can I fix this? Can you tell me which component is connected to the pad? Thank you.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Chris 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 1,212
