주요 콘텐츠로 건너뛰기
Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
1233 질문 전체 보기
Home Button Still not working after replacing button and flex cable?
So i am having difficulty getting the home button to work, i bought a new button and flex cable online, replaced as shown but the home button is still unresponsive?
The button feels better and clicks down like it should?
Any other suggestions?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 2개
Have you tried shorting the home button connector pins to see if the phone responds to that as a home button click?
No I have not? Is this easy enough to do?
댓글 달기
답변 2개
선택된 답변
take a flat head screwdriver or some other metal instrument. what you want to do is check if the home button function works ok without the use of the home button.
the part you want to short out is on the dock connector, its the 2 gold springy prongs that would come into contact with the rear of the home flex. go into an app and then touch the 2 prongs together with said instrument. if it returns to home screen then all is good and you probably just have a faulty home flex. (as long as you also have the home flex positioned correctly and stuck down)
해당 답변은 도움이 되었습니까?
점수 5
댓글 2개:
Thanks, i managed to short the 2 prongs and when i did it returned to the home screen so i assume its just a faulty flex cable. Thanks
Yep, faulty flex cable most likely for home button.
댓글 달기
Any pic to see it, I have the same problem after replacing the screen and Digitizer ...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
oteesdale2000 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 89
