perserving heel and soul using silicone
New boots showing wear after being worn 4 times. Would a coat of silicone protect against wear?
좋은 질문 입니까?
좋은 질문 입니까?
You may be able to use silicone to rebuild your worn outsole, though the success of this repair might depend on the product you are intending to use and the type of material your outsole is made out of (leather, rubber, etc.).
A tried-and-true product specifically used for shoe repair is Shoe Goo. Here are two guides to help you complete the repair:
Hope this helps!
안내서
난이도:
운영
30 minutes
안내서
난이도:
아주 쉬움
15 minutes
해당 답변은 도움이 되었습니까?
If these are leather you can use several things:
These are made of hard plastic:
http://www.amazon.com/Traveler-Plates-Na...
These are nylon:
http://www.ebay.com/itm/10-pr-Guard-Heel...
These are metal:
http://www.ebay.com/itm/DIY-metal-BIKER-...
These are hob nails, worked well for the German army:
해당 답변은 도움이 되었습니까?
Here's something you might try. A bit costly I admit, but your shoes will wear down the pavement instead of the other way round ;)
(sorry, couldn't resist)
해당 답변은 도움이 되었습니까?
You dont want to walk on any glass floors with those shoes
24 시간 전: 1
7일 전: 14
30일 전: 48
전체 시간: 4,065
댓글 1개
I sprayed silicone on the boot material
michelle.jarvid 의
