주요 콘텐츠로 건너뛰기
2013년 9월 25일에 발표된 Samsung Galaxy Note phablet 시리즈 3 세대. 모델 번호 N9005로 식별 가능.
248 질문 전체 보기
질문 마감됨
Camera split in half
I opened the camera application to take photo. The camera seemed that it had split in half and the right part was flashing green. I closed the application and reopened it and it seemed to work fine till today that the phone had the same issue
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Most likely your camera has to be replaced. Is this the front or back camera?
You can buy the front and/or back camera from here, note that these are compatible with the SM-N9005 phone model.
[연계 제품이 누락 또는 비활성화 됨: IF232-003]
[연계 제품이 누락 또는 비활성화 됨: IF232-008]
Guide on how to replace the rear camera:
Samsung Galaxy Note 3 Rear Facing Camera Replacement
You can use the same guide to help replace the front camera. The front camera has a black metal plate behind it to hold it in place. You can easily lift the black metal plate up with some prying tool. The front camera should come out easily without much force.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 177
