주요 콘텐츠로 건너뛰기
Fourth generation Honda Civic
33 질문 전체 보기
possible vacuum Leak, clogged pcv, or idle control valve
1990 honda civic dx hatchback. Starts and runs but when I push the clutch in it revs way high. Also idle speed is really high as well. I have changed the oil pan gasket but I don't know what else ,other than a clogged pcv valve, could have caused it to blow.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
You may want to check the EGR valve If the diaphragm is leaking it will cause an increase in Idle speed. Pull the vacuum line from the EGR while the car is running if the idle speed stays the same the valve is faulty if it changes speed its ok. Next what blew ? You said"I don't know what else ,other than a clogged pcv valve, could have caused it to blow". The oil pan gasket blow out from the pressure from an clogged PCV valve? Did the valve cover gaskets blow as well ? Or was it something else that blew?
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
mchlwngr 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 539
