주요 콘텐츠로 건너뛰기
모델 A1278, 2012년 6월 출시. Turbo Boost가있는 Intel 프로세서, 최대 512 MB DDR5 비디오 RAM
1624 질문 전체 보기
Charging / Battery Issue
Basically i had a very corroded board after a friend water spill when i bought it for £500 the week before, im determined to fix it.
Managed to pick up another identical model for free which had its own problems.
so far i have replaced.. Mobo, HDD, Battery, Ram, Dc-in (twice), sata cable for HDD, & ribbon cable for battery sensor lights.
Its still not recognizing the hard drive as i was having mount problems but my main issue is with the battery.
problems..
the macbook will power on if battery has been charged in another model but cannot take charge itself or run off ac power.
X where battery icon should be, it also says
"power source - battery
battery not available" - or something to that effect.
it will not charge what so ever, occasionally when magsafe has just been plugged into another macbook it will mimic the bright orange or green light for a minute or two and then dim.
battery works fine in other models, tried all resets.
charger works fine.
new mobo + charger + dc-in + battery - wtf?
im completely out of ideas at this point. it has no OS due to the fact it cant find the hard drive currently, that surely cant be affecting battery/charge, can it?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
The hard drive bracket (cable) is notorious for breaking. Additionally, have you tried a SMC and/or PRAM reset? My guess is that the SMC needs to be reset. You can find out how to do that here: https://support.apple.com/en-us/HT201295
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
chris bing 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 103
