주요 콘텐츠로 건너뛰기
Sanyo 디지털 카메라 수리 안내서 및 지원.
69 질문 전체 보기
Card Error---- only works with internal memory.
I have a Sanyo VPC-E2100. When I attempt to use an SD card, the viewer screen is blurred and says "card error". This is a new SD card and works fine in other devices.
The camera works fine however, without the card and will take pics and store to internal memory. Help!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개:
Hi Angela,
Have you tried formatting your SD card? Keep in mind that formatting a card will erase all data, so make sure to transfer your images (if any) to your computer first.
댓글 달기
답변 2개
First off look at the card. I have this camera and it is a really good camera. You can use a class 10 sd card in it. I use a class 10 sd mini with an adapter. What you want to look for is a small "10" on them. You can also use a lexus 8Gb down to a 2MB. The max is a 32Gb I use one that comes from sandisk, just make sure it is class 10.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have a sanyo vpc-T1060 camera. I bought a new san disk, 1 gb and when i put it in the camera i get a messageprotected card. What does that mean and how do i fix it. I put the old s card in and that works find. hope you can help bill russell43us@yahoo.com
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Angela Beck 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 27
전체 시간: 535
