주요 콘텐츠로 건너뛰기
This PC is a Dell Inspiron 3000 Series laptop with an AMD processor and a non-touch display. It's model number is 3541.
Why are several keys on my keyboard not working?
When using the laptop I cannot type using all of the keys, as some of them are not responding when pressed.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Was there any water damage to the keyboard or did this spontaneously happen?
spontaneously
댓글 달기
답변 3개
선택된 해법
Hi Edward,
This could be due to any sort of damage, but most likely if you dropped or accidentally spilt something on it, you could need a new keyboard altogether. Let me know if this is not the case, but if it is, please refer to our Keyboard Repair Guide located on the device page.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
I spilled water on the Dell Inspiron 15 3000
Series and now the g and h key is not working. I went to control panel and delete the keyboard and reinstall and checked for updates nothing worked. Do you think I'm going to have to replace the whole keyboard?
i do have the same issue have replaced the keyboard but in few days later it had reappear ..
댓글 달기
가장 유용한 답변
Good morning Edward,
You will likely need to replace the keyboard. In general that's not a difficult job at all. There is not a repair guide on here so this link should help. https://www.youtube.com/watch?v=soDpr5_G...
Good Luck
Holger
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Three keys close to each other (o, l, and period) quit working on my Dell Inspiron 15 5000 series laptop which I have only had for two months over a year (no more warranty, of course). I gently pried the keyboard off using the indentations at the top, then wiped the area of the three keys that weren't working with an electronic wipe. After it dried I put the keyboard back on, making sure that the tape-like parts were snapped in with the correct side up. After that it worked fine, better than what the Dell tech person had me do (turn off, remove battery for a while), which only helped for a few minutes. No sooner was I off the phone with her when the problem returned.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Edward Pacheco 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 24
전체 시간: 5,751
