주요 콘텐츠로 건너뛰기
2009년 6월 출시 / 2.66, 2.8, 또는 3.06 GHz Core 2 Duo 프로세서
300 질문 전체 보기
Keyboard replacement for intermittent keys
Is it possible to replace just the keyboard on this machine? It's done a lot of typing and the home keys have started acting intermittently. I'd rather not replace the whole top case if possible.
I've already popped the keys and cleaned out the underside of them but that had little effect.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
Yes, you can replace the keyboard alone. You'll need to look on eBay to find one for your exact model. Follow the IFIXIT guide: MacBook Pro 15" Unibody Mid 2009 Upper Case Replacement and follow this YouTube: MacBook Unibody Keyboard Replacement.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
It turns out that you can, in fact, replace just the keyboard. I have yet to do so, but I was able to buy a replacement keyboard assembly off Amazon for about $30. You can get them cheaper if you don't want the backlighting.
It appears that there are about 50 tiny screws that holds the keyboard to the top case so that's going to take a while but it should work out great.
I'll report back here when I get it done.
댓글 달기
귀하의 답변을 추가하세요
David Jonas 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 198
