주요 콘텐츠로 건너뛰기
처리 속도가 빨라진 iPhone 3G 개선 버전. 이 기기의 수리는 3G와 유사하며 간단한 스크루드라이버, 비집는 도구가 필요합니다. 모델 A1303 / 16GB 또는 32GB 용량 / 검정 또는 흰색 플라스틱 뒷면.
1500 질문 전체 보기
질문 마감됨
Does iFixit sell a vibrator switch for the iPhone 3GS?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 4개
선택된 답변
The vibrator can be replaced individually, but most places sell it as a part of the back panel due to shipping costs. Buy a back and remove the vibrator to install it in your phone.
The guide to install it can be found here.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
가장 유용한 답변
Here is the guide for replacing it, but I don't believe iFixit sells the vibrator itself, I know on the 3G it was attached to the headphone jack, but I don't think it is so for the S. You'll have to look elsewhere for that.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Can anyone tell me how to remove the vibrator switch from the metal housing it's in? The original looks like a rivet because the back looks like a mushroom. The new switch which is part of the flex has the two legs but they are straight. Do I need to solder them or do anything else once I stick the new switch flex to the housing?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
mikev0521, it would be better for you to ask your own question. this one here has had no answer for 8month. your question shows up as an answer. I am certain that there are plenty of knowledgeable people out there that are going to help you, if they see you are asking. Good Luck
댓글 달기
The vibration switch is actually a part of the headphone jack assembly. Here is the part and here is the guide for the replacement
Hope this helps!
해당 답변은 도움이 되었습니까?
점수 -1
댓글 1개:
what, did you read Nicks answer to get this response?
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 3,824
