주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2376 질문 전체 보기
Problem with dock connector (Possible short circuit)
hi, my name is julio and i need help with my iPhone 4.
So my iPhone keeps in loop apple logo but just if it connected to a computer or a ac power adaptor. If i remove the cable the iPhone goes down. I try replacement of battery but nothing helps. I think the problem is with dock battery connector because i search a little and i found this image:
So i pick up the multimeter and i check the continuity. I note that The last pin and the first pin are on short circuit. I think that the first pin is ground ant the last is vs (red wire) so make sense the power problems but i don't know how to fix this short circuit.
I'm asking for help to solve this guys.
Thanks a lot.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
Try cleaning dock connector with isopropyl and toothbrush first. Then if that fails replace dock connector
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
I think the problem isnt with Dock ... I just test continuity there.. I think that maybe should be a capacitor caused by water drain because the water marker apparently shoes positive ...
i strongly recommend you at least try a dock replacement. 5 minute job and only a few £$
ok, i try like you said replace the dock and still the same ...
댓글 달기
귀하의 답변을 추가하세요
julioficabem 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 116
