주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
No Cellular Service On Phone
My iPhone 6 has been having some issues with it's cellular service. The phone will say no service, and so I turn the phone into airplane mode to restart the signal. The phone will continue to search for service, but won't pick any service and just continue searching.
Before I would restart all setting and this would fix the phone for a few days. Now I tried to do this and my phone won't pick up anything. I can pick up wi-fi and bluetooth fine with zero issues. I reset all my settings and content as if it was a brand new phone and it still doesn't work.
Is there any way to fix this? Also if I need a part to change out what would I need?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Hi
Try replacing the signal antenna and see if this improve the signal.
Signal antenna is coming with charging flex. See photo:
Good luck
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
With a sim inserted.
Go settings > general > about can you a iccid number?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I have the similiar issue. And I can see a iccid number. What to check now?
댓글 달기
귀하의 답변을 추가하세요
spcrandall0403 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 4
전체 시간: 438
