주요 콘텐츠로 건너뛰기
Model A1137 / 1, 2, or 4 GB capacity / black or white plastic front
68 질문 전체 보기
Not responsive to trackwheel.
Powers On ok, but that is all it does. Cannot scroll to any menu.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
Probably needs a replacement clickwheel or there is liquid damage to the unit causing it to behave erratically.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
does not respond to the trackwheel.
Only showing 1 song and plays only that song.
Has not gotten wet.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Have you tried to reset your iPod? Have you tried to connect it and checked with iTunes how many songs you have on there as well as the format of the songs? Have you tried to play them through iTunes? Does your click wheel allow you to make any menu changes?
I'd too say that. Furthermore, I dunno it's a related issue, but the iPod Nano recently got a recall, still active AFAIK, because of heat issues with the battery, with melting plastics as a possible end result.
Maybe I'd give that a check.
댓글 달기
귀하의 답변을 추가하세요
mcarmi2k 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 2,802
