이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 3개:
@hands4talk turning dark as in darker or as in black? Sounds like an issue with the inverter board. Have you opened the TV up and taken a look at the caps on the boards? What have you tired?
@oldturkey03 when I turn my Tv on it only lets me see the Toshiba writing and then it goes dark. It still turns on but it doesn't show anything else on the screen. Would you happen to know how to fix this?
Lilia Klass what model is it? do you still have the onboard menu or does it go blank right after the Toshiba writing with nothing showing (not even the menu)?
oldturkey03 의
Lilia Klass 의
oldturkey03 의
