주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
Screen assembly- is there differences between different iPhone 5?
Hello!
I was just working with my friends Iphone 5s. I was trying to change the screen assembly, and I think everything went well, but the solution was bad.
Now there is vertical stripe going across whole screen, and when trying the number buttons number 0 is not working.
I took the part from my home, so I don´t know if it was Iphone 5s or another Iphone 5 part. Is there differences between those?
Should I just open the whole thing and but it back (I mean if some of the flex is badly on) or should I change the part to an another?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
It sounds like you have either a damaged digitizer cable, or it is the wrong part. To answer your question, yes, the iPhone 5 display and the iPhone 5s display are different, and an iPhone 5 display will not work in an iPhone 5s. However, to me, your problem sounds more like a damaged digitizer cable. I would just get a new part. Hope this helps.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
aspi91 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 47
