주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
What is my iPhone dying so quickly
When using my iPhone I usually charge my phone to 100%. However my phone tends to die around 70% to 90%. Then after a few minuets I turn it on to find it at around 70% to 90%. When it's not connected to a charger it would turn off right after the device has been powered on. i drained the battery but it would again power off if no charger is connected to the phone. I was wondering if I should buy another battery for the iPhone 6?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
Hi Eric
What may be beneficial for you is to contact a Apple Support Rep and get them to run diagnostics for you.
If your battery fails, then you can consider replacing the battery.
It is a common misconception that it is "good" to discharge your iPhone battery , lithium-ion batteries found in iPhones should not be discharged to the point of zero, it will shorten the battery life of your iPhone.
Regards
Brayden
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Eric Del 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 5
전체 시간: 125
