주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
질문 마감됨
Touch ID isnt working after screen replacement!
A couple of days ago i replaced my broken iPhone 6 screen (I did it myself). Everything is working fine, except my Touch ID. My home button works. How to fix this? I still have the broken screen available.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개:
Did you make sure to keep the original home button? For iPhones with Touch ID, it requires the original home button. Almost like an extension of the logic board.
Yes i have the original home button!
댓글 달기
답변 2개
Hey there! The iPhone 6 keeps track of the original home button for the touch id. When you replaced the screen, did you get the complete assembly with home button? If you did, you phone is just protecting itself from someone trying to break into your phone. If you didn't, the gasket or home button may not be fitting well, and may not be registering as the stock part. I'd check these two possibilities, and ask again if the issue isn't resolved.
Best of luck!
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Thank you for the answer! I replaced the original screen, but the home button is the same! I'll check if everything is fitted as it should be!
I didnt work for me!
댓글 달기
What has happened recently is that apple tightened the tolerance on the home button. When replacing LCD's make sure you keep the home button and home button ribbon together or else this issue can come up also. Make sure your using the original ribbon with the original home button.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 3
전체 시간: 95
