주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년 9월 19일에 출시된 이 5.5” 스크린 iPhone은 iPhone 6의 큰 버전입니다.
Dead after screen replacement
Hi all-
My iPhone 6 Plus was working fine, but had a cracked screen. After replacing the screen using the iFixit kit, the phone is completely dead. It will not power on, reset, or respond to iTunes when plugged into my Macbook. It does get warm when connected to the charger, but that's it. Any suggestions?
-Garland
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 3개
I think a cable is not connected, open the phone and look if everything is connected.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Yes check all your connectors to make sure they are connected correct. Unhook the battery from the motherboard and then reconnect after 10 mins, power up and see what happens. Do you know what % your battery was at prior to doing the screen replacement?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Plug it into your Macbook, and do this: How to Force Restart an iPhone 6 Plus
If it doesn't show up then it's probably the logic board. I would open up the phone again if the method above doesn't work, and check to see if any components missing off the logic board by the screen connectors.
If it does however show up, then I would check to see if normal things are working such as the silent switch or Siri. If they don't (I had this happen to me on my 4s) then it might be the logic board (in my case it was).
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
garlandstephens 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 14
전체 시간: 216
