주요 콘텐츠로 건너뛰기
2세대 iPhone. Model A1241 / 8 또는 16GB 용량 / 검정 또는 흰색 플라스틱 뒷면. 첫 번째 iPhone보다 수리는 더 간단하며 스크루드라이버, 비집는 도구 그리고 흡입 도구가 필요합니다.
1169 질문 전체 보기
Why does my iPhone have a white screen with black lines?
I tried to turn on my iphone the other day and when I pressed the home button all I saw was a white screen that had a few thin black lines on the screen.
Everything else still works on the phone I can receive and answer calls, the touch screen still works.
Is this a problem with the connectors, or is the screen broken?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
u may need to get a new lcd screen or check the cables to see if it is jutting out even the slightest bit. when checking the cables make sure that all the tiny metal clips are there and none are missing from the rows.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
One of the cables was not plugged in all the way. Thank You.
댓글 달기
hey man what cable was the one that wasnt plugged in cuz i have the same prob was it #1 2 or 3?
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Check cable #1 Zee.
ahh okay i checked it its fine, i dropped my iphone from about a foot off the ground and then the screen went white. its not cracked or anything is there something else i can do to fix it?
댓글 달기
귀하의 답변을 추가하세요
Maximus 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 8,425
