주요 콘텐츠로 건너뛰기
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
Dark spots at the bottom of the screen?
I changed my screen yesterday and this morning when I turned it on there was four Black spots at the bottom of the screen. I can only see them when the screen is light. Do you think that I broke the LCD?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
can you attach some photos?
댓글 달기
답변 2개
Let me guess when you removed the LCD, you didn't realize that it was tapped down on the home button end and you flexed the screen when removing it. The LCD is pretty fragile, did you follow a guide on here to repair? I am assuming your LCD was fine before repair. So you either cracked it some how when removing or its an defective LCD. You can also try blowing out the connectors with canned air as you might have some small debree on it. Also make sure there isn't any damage on the connectors (on the LCD cable and board) if you find damage you know were to point to.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
thank you!!!
댓글 달기
Youre doing a pretty good job so far @cote885
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Mathieu Cote 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 1,246
