주요 콘텐츠로 건너뛰기
Beats Solo 2 Wireless headphones are a wireless version of the Beats Solo 2. Released in 2014. Model number: MHNG2AM/A.
48 질문 전체 보기
Why are my beats only paring up and working while charging?
The beats will only work if they are connected to a power source, the Aux cable works perfect, but whenever i want to try the wireless mode it wont work, for example :
If the beats are being charge and i pair my iPhone it works and everything,but if I unplugged them from the charger it wont even turn on the Bluetooth
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 4개
I have Zedd solo doing the same thing
I have a Polaroid doing the same thing
This gonna sound weird but open the beats on the side that has the lights then close them back up and then charge it worked for me hope this helps
Cam dynasty if you see this you are a true legend
댓글 달기
답변 5개
선택된 답변
Two problems I would investigate:
1. is the internal battery dead?
2. loose connections with respect to the internal psu/battery
try opening one of the speakers - the side with the charger port. take a look at these images for some guidance
해당 답변은 도움이 되었습니까?
점수 9
댓글 3개:
Excuse me, but which pictures ??
Ah sorry about that: Here are some links I just found
some of these images and articles are not specific to your edition but all speakers are constructed the same way, especially regarding power input and battery placement relative to speaker element (because of electrical noise from AC-DC-AC conversion and effects of relative distance and placement of electronics components on creating issues with use or the need for additional noise-reducing systems (which as you know, more things to subdue the symptoms could just mean more isolated malfunctions and harder to fix as there's no part to swap, when the entire system is degrading.)
let me know how it goes!
http://www.core77.com/posts/52314/A-Look...
http://www.head-fi.org/t/632063/dre-beat...
http://www.head-fi.org/t/688434/my-old-s...
http://gizmodo.com/are-beats-headphones-...
please solved my problem.When I plugged it can be work.When I unpluggedit can't be work.
댓글 달기
I have this problem just like when I plugged than it can be work.When I unplugged it can't be work.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
My only works when it’s charging but when it is not charging it doesn’t even turn when battery is 100 percent and I got them today
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Unfortunately, this also applies to me. My Bluetooth headphones only turns on /connects to my iPhone when the headphones is charging. If I disconnect the charger from my headphones, it will turn off automatically. WTF?! Why this happens? I never have this problem before. This REALLY REALLY REALLY ticks me off. Someone better have a better explanation for this.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Mine are doing the same thing. Mine are the wireless beats and I haven't had them a year
댓글 달기
Super weird, had this same issue. I’ve had mine for a while now and I use them for probably 2-4 hours a day, whether it being at the gym, doing yard work, or even running in the rain lol.. yesterday it was drizzling outside and I was having a football catch outside with them on. I went inside and they wouldn’t work right, and wouldn’t turn on at all unless plugged in with the charger.. I tried basically all the methods and nothing worked for resetting them, so I just simply tried using an aux wire instead (3.5mm jack) and they worked fine after! They turn on flawlessly and connect wirelessly with ease. Hope this helps!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
briantrevino 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 10
7일 전: 77
30일 전: 353
전체 시간: 32,211
