주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repair guides and support for your Samsung TV.
TV set is dead
After resetting the Samsung UE37D5000 TV with OK until the led blinks etc I have decided to enter the reserved menu of the TV because my image during playback of movies on HDD suddenly was quite dark and not well defined besides the fact the all the other functions were ok. On the diagnostic it said that " T-con Failure"
I played a bit with the menu and submenu and suddenly the power went off.
Now the TV is dead.
The red LED doesn't display anymore etc.
I made some test. The fuse is okay on the PSU. It seems all the voltages are there. From a visual inspection no capacitor seem bulky.
I tried to disconnect the Logic Board and all back light led's came on. I suspect the T-Con but I am not sure. Any advise? Even because to find the T-Con is quite a challenge.
Kindly advise if you can or if possible some logical tips after all the mess I did and for which I only have to complain to myself.
All the best Rob
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
it probably isn't dead, a relay might have triggerd and made the light disappear, or you may have to use the remote tv button power on the said tv.
trusty,
BACON!!!!
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Hi Bacon, no I did not manage. I tried several time and it is a touch screen control on the operate etc. I think I killed the tv hehehe. Shame it was so nice and crispy apart from the HDD.
댓글 달기
가장 유용한 답변
Here's how to diagnose and repair/replace the T'con board: http://electronicshelponline.blogspot.co...
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
Hi Mayer, thanks a lot to you too. I will definitely have a look at the site. I review anyway some other sites and they say that if the light goes white (in the dark) the t-con is gone. My tv is dead completely but as I said if I remove the logic board flat cable the back lights go on. Confusion !!!!
댓글 달기
답변을 추가하세요
rob612000 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 14
전체 시간: 3,113
