주요 콘텐츠로 건너뛰기
모델 A1051 / 4 또는 6GB 하드 드라이브
90 질문 전체 보기
Can battery be charged outside of case?
Looking to be able to charge my spare Mini batteries using a portable Li On charger. Is this possible? I am repairing ipod minis as a hobby and I have several batteries that I want to charge before I install them! Is this possible?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Single cells can be charged using a regulated power supply set to a voltage of 4.2 V, and a current limit appropriate to the size of the cell you'd want to charge, say about 0.5C - which means, if your cell has a capacity of 1000mAh you'd set the current limit at 500mA. A seasoned electronics engineer could slap together such a circuit from parts in the junk drawer. Carefully check that the voltage doesn't drift upwards as the circuit warms up under load, and adjust accordingly if it does.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Steve Barthel 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 17
30일 전: 18
전체 시간: 239
