주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2013년 Canon에서 출시한 DSLR 카메라인 EOS 70D에 대한 수리 가이드와 지원 정보입니다. 이 카메라는 모델 번호 DS126411로 식별할 수 있습니다.
Touchscreen was hyperextended. Can this be repaired or replaced?
So my 70d was inadvertently knocked over yesterday at a wedding rehearsal. The flip out touch screen was open and, as it fell, it hit the grass first. The screen still works and functions, but now it has been hyperextended such that it won't return to the home position when swiveled around and relocated against the camera body. I will probably pursue having it professionally repaired but I wanted to at least ask 2 questions:
1. Has anyone ever had this happen and then possibly repaired it themselves?
2. Whom do you recommend for repairs like this?
Thank you for your time.
~Chris
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
가장 유용한 답변
Hello Chris,
There's a video on YouTube (if you haven't already seen it) that gives you instructions for a teardown, with the specific purpose of replacing the Canon 70D LCD Assembly. {I got mine for about $120 shipped on aliexpress}
Here's the link:
https://youtu.be/N4jD6_6R_r8
You will need an electrical socket set (or eyeglass socket set) because the screws are "super duper"<-- technical term-->small. You don't have to worry about losing them because you already have them in the new assembly piece.
Takes roughly an hour. Well worth it though!
Let us know your success!
E Johnson
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Good vid, but the guy must be a pro working that fast.
의 공유
Actually, if you are motivated to do it, take your time, and keep track of the pieces to go in reverse, it's super easy. Obviously though, if you're scared to mess with your camera's internal parts, you should get someone to do it who does stuff like this.
의 공유
댓글 달기
답변을 추가하세요
Chris Thompson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 19
전체 시간: 1,343
