주요 콘텐츠로 건너뛰기
The third-generation Ram was unveiled on February 7, 2001 at the 2001 Chicago Auto Show. This was a major update including an all new frame, suspension, powertrains, interiors, and sheet metal.
Where is the fuel filter?
location of fuel filter?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 2개
gas or diesel ?
Thanks for the help.
댓글 달기
답변 1개
선택된 해법
Depending on the year of the truck if its gas or diesel there are several locations . On the diesel its located next to the master brake cylinder. On older gas models its mounted on top of the fuel tank next to the sender unit on some of the newer models its mounted to the frame rail next to the fuel tank . Easiest way to find it is to start at the fuel tank sender unit and follow the fuel lines to the engine. you'll find it in there somewhere. If your not seeing it odds are its one of the ones mounted on top of the fuel tank. Hope this helps
이 답변이 도움이 되었나요?
점수 5
댓글 달기
답변을 추가하세요
Terry 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 9
지난 7일: 34
지난 30일: 125
전체 시간: 28,127
