주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.2 GHz (Turbo Boost 최대 3.4 GHz), 2.5 GHz (Turbo Boost 최대 3.7GHz) 쿼드-코어 Intel Core i7 프로세서.
773 질문 전체 보기
질문 마감됨
Is that problem with anti-glare layer on Retina screens still there?
Hello everybody!
I'm planning to buy a Macbook Pro 15'' (2015) MJLT2. But after I made a research about it I found a lot of negative responses about a problem with an anti-glare layers. It seems that this issue is peculiar to MBPr's from 2012 to 2014.
Some guys even created a website to show Apple how global that problem is:
http://www.staingate.org/
So my question is: Is that problem with anti-glare layer on Retina screens still there, for Macbook Pro Retina (2015)? Or is it solved in the newest Macbooks, starting from 2015?
I would appreciate any help or tips. Thank you all in advance! :)
Best regards, Optimix
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
I wonder if a tempered glass screen protector would alleviate this issue.
Thank you for the answer :)
Hmmm... maybe it's a good idea. Guys, anyone used some kind of slass protectors on Retina displays?
댓글 달기
답변 1개
가장 유용한 답변
short answer yes the problem is still around on 2015 models but apple are offering a free replacement screen on all affected models as long as it has been reported to apple within 3 years of purchase.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Thank you for a prompt answer!
As I heared this Quality program from Apple will end on October, 2016. And it would be really bad to stuck with this problem in 6-7 months of using the Macbook Pro.
Darn... After your words I really don't know if it's a good idea of buying a Pro version :(
i would suggest contacting apple about the quality program as it shouldn't end so soon
but if you are buying new you should not get a faulty laptop as apple will have hopefully removed the faulty screen from production.
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 866
