주요 콘텐츠로 건너뛰기
eMac은 교육 시장용으로 설계된 올인원 G4-기반 Mac입니다. CRT 화면을 사용하는 마지막 Mac이었으며 학교 및 기타 기관에 저렴한 가격으로 판매되었습니다.
47 질문 전체 보기
Replacing CRT with LCD
Dear I know it is outdated but I have an e Mac G4 1.25 GHz machine which I love very much and am going to replace CRT with an LCD but I want to use its own power supply to run everything and have omitted the high tension components and now it switches ON but needs to connect the round IVAD board so I need the circuit diagrams of analog board and details of Vga Connector Pin 4&10 with yellow wires and said to be I2C line.
I will be very thankful if you can provide me on rinclairelectronics@Gmail.Com
Thanks anyway but please reply whatever.
Ramesh
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 3개
Could you please tell me about conversion CRT to LCD, I have one eMac G4 700, and want to move CRT to LCD :(
What you want to know and technically what can you do in electronics, I mean at what level you can work and understand.
Oh sorry for missing this message. I can solder and have suitable instruments for that :)
댓글 달기
답변 1개
선택된 답변
Here is the pinout of a VGA cable. The VGA spec is a standard, so this should be universally applicable
I couldn’t find a diagram of the board, but I did manage to dig up some info that could help. You will have to view it via The Wayback Machine as the original site is long gone.
https://web.archive.org/web/200603131248...
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Dear I've done my conversion following this post only but I couldn't get the LCD he used so all is working but as he said it black out as I start game.
댓글 달기
귀하의 답변을 추가하세요
Ramesh Mistry 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 11
전체 시간: 1,081
