주요 콘텐츠로 건너뛰기
iMac G4에 대한 수리 정보.
Replace the Screen Backlight?
I have a G4, 1.25ghz, 20inch Imac with a blown backlight. How complex is it to fix this myself and what are the approximate cost of the parts? I am getting estimates of over $1000 in the NYC area to fix this.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 2개
가장 유용한 답변
You would need to partially dissasemble the screen assembly by removing the hex screws around the display. Then, partially lift the panel out, and disconnect the LVDS cable, and inverter power cable. Then remove the LCD Panel/ faceplate. Then you can disconnect the inverter and replace it.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
The new inverter might cost around $100 though
댓글 달기
So is the Inverter another name for the backlight? I think they said the backlight bulb is what blew out. Where would I source the part(s). Thanks in advance.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
mtsquared2 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 2,070
