주요 콘텐츠로 건너뛰기
Nintendo DSi는 닌텐도 DS 라인의 세 번째 시리즈이며, 2008년 말 일본에서 첫 선을 보였습니다.
262 질문 전체 보기
질문 마감됨
Please help me fix my Dsi.
One day I decided to go back and get some nostalgia by playing my DSI and nothing happens when I press the PWR button, like nothing at all. No light powers on, no screen powering on, and the only sign of life is the charging light.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
I should probably note that I have a 3DS. Help would be useful tho.
댓글 달기
답변 1개
선택된 답변
Hi Eddie,
It sounds like you've got 1 of 2 problems going on.
  1. Either your F1 or F2 fuse has blown.
    1. F1 is located next to the charge port
    2. F2 is located on the opposite side of the battery terminal
  2. Something isn't seated properly.
    1. Wifi card
    2. Ribbon from the upper/lower LCD
    3. Other various ribbons or connections not seated properly
From my experience, this is probably going to be the 1 option and probably point #2. If you've checked both fuses with a multimeter on continuity mode and they're okay, start checking all your ribbons and such as indicated in point 2.
Hope these help and you get your system back up and running. Good luck!
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Thank you! Turns out it was the Wifi card. I replaced it and now the system works!
Excellent! I'm glad I could help and my info worked out for you.
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 79
