주요 콘텐츠로 건너뛰기
다섯 번째 Google Nexus 휴대폰. 2013년 10월 31일에 공식 발표되었으며 4.95” 1080p 스크린, 2.26GHz Snapdragon 프로세서 및 LTE 지원을 자랑합니다. Android 4.4.2, KITKAT. 제조사는 LG.
222 질문 전체 보기
Phone Dropped: Black screen
I dropped my LG Nexus 5, with a heavy impact on the floor. The screen just hung up and became non-responsive. When I long-pressed the power button it just went blank and didn't turn on again. Charging seems useless as it doesn't respond at all. Is it worth trying to replace the battery? I opened up the phone, couldn't notice any visible damage to the motherboard.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 3개
가장 유용한 답변
I agree. I've fixed more Android screens with broken internal lcds than busted glass lately. Android lcds are usually paper thin and crack very easy. Look at it under a lamp or direct light and youll usually be able to see a few streaks that indicate it's cracked.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I think you get a damage on your LCD or Touchscreen. I had the similar issue on my old iPhone 3GS. I am to 90% sure that this is the issue.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
This might very well be the case but I couldn't hear any sound from the phone nor does it react when plugged into a computer. Thats why I thought this was either a battery or motherboard issue.
Have you tried a "Hard-Reset"? Try to connect it in "Bootloader" Mode through a computer with "fast boot" installed and type in the following Command: "fast boot device" or "fastboot devices". If you see you device, only the screen is cracked and you need to wipe it in the recovery, had this issue on the Desire X of my mother.
댓글 달기
I recently dropped my Nexus 5 and the internal lcd showed some lines on the left side of the screen. The funny part was that the glass didn't have a single scratch, but it still had to be changed...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Srinivasan Venugopal 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 785
