How to correct iPhone 6 ghost typing and screen freeze?
Hi,
My iPhone 6 started occasionally types/clicks things on its own or the screen totally freezes. I can't even answer my calls because it stays frozen while i'm trying to slide to answer and i can't make calls because if i try to touch name A it regisers touch at name F. The problem still persists even after trying a number of new screens so its not the screen. Could anyone please help me with a solution to this?
좋은 질문 입니까?
댓글 3개
Have you tried holding the power button for 5 seconds while the battery is unplugged to see if that helps with the digitizer / touch screen issue? Do you have like a grey bar at the top of the screen by any chance?
Also did you buy screens from the same supplier or got it repaired from a mobile phone repair shop?
Ben 의
Hi Ben,
I tried what you said with the power button but that didn't work :(
Also to clarify I'm still using my original screen which is tested to be working with other iphones. I tried fitting a couple of aftermarket screens to my iPhone and when that didn't sort the problem I put the original back in.
Any other solutions?? Anyone?
emarr 의
Where are these aftermarket screens from? They sound cheap and low quality in my opinion.
Ben 의
