주요 콘텐츠로 건너뛰기
Released on May 1, 2015 by LG. Can also be identified by LS770.
26 질문 전체 보기
My lg g stylo power button doesn't work
My power button doesn't work on my lg g stylo. Does anyone know how to fix it?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 9개
Did you ever solve this? I'm having the same issue.
I'm having the same problem
Lol if Albert Einstein can't fix it then nobody can XD
My power button on my stylo 4 isn't working
My button on the back of my phone don't work
댓글 4개 더보기
댓글 달기
답변 9개
가장 유용한 답변
This worked for me.. take off the back case then plug in your charger. With the charger in remove the battery and put it back in. Restarted my phone. The power button is still not working but I can access it by tapping the screen. Hope this helps
해당 답변은 도움이 되었습니까?
점수 10
댓글 10개:
Thank you that worked. I had the same problem and I knew there must be a way to get it turned back on.
Thank you! This worked for me also!
WORKED!!! You're a genius! :)
this also worked for me
too !!
OMG I had the same prob,I have been trying to figure this out for weeks and it worked thank uuuu
댓글 5개 더보기
댓글 달기
Taking off the back and taking out the battery for 15 seconds worked for me. I also noticed that the battery symbol showed it as charging, even off the charger, so that mustve been the glitch.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Try updating Android. That actually worked for me.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
omg this totally worked.. thank god!!!!!!
댓글 달기
Mine does that too… just keep plugging and unplugging the charger in a bunch of times and it eventually turns on.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I have to actually connect the charger and then in some cases kind of press the bottom of my phone to get it to vibrate and come on and then sometimes when I take the charger out it goes blank and I can't turn it on again but it does work with a charger plugged in
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I was having the same issue earlier today. Tapped the power button repeatedly about 20 times out of frustration then held it down like usual the last time & it started working again. Must be a glitch or something. Hope this helps.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I took the phone completely apart with a small screw driver and clean the contacts that lead to the power and volume buttons under the inside cover and put it back together and now it works fine.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I could do this. Thanks!
댓글 달기
I went to setting in the display area and and turned off the switch for the power button and then turn it back on I haven't had problems since doing it
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
plug in the charger and press the volume down button holding down until it comes on if that did not work try it again still not working try different combinations with charger and volume buttons that worked for me but it took a few tries for sure. hope it works for you.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
tamikarose5 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 24
30일 전: 69
전체 시간: 17,401
