Died after fall down
I fell my phone in the floor then it become very hot then switch off died
I try to switch it on , recharge it
No way
What and where the damage happend?
Can the battery damage from one fall?
For your advice
좋은 질문 입니까?
No way
For your advice
좋은 질문 입니까?
Going on with what "Ben" said it is most likely the power controller chip and it is very hard to replace and it may have damaged other items in the phone as well so... Time for a new one....
해당 답변은 도움이 되었습니까?
Did you try to restart it by holding the home and power button for about 10 secs?
해당 답변은 도움이 되었습니까?
How to restart it if it not working at all, there is no power
Pretty sure the only way to fix is getting some IC or component chips replaced. Its hard to find which component chip is at fault on the logic bard upper half.
It's 50/50 chance of fixing so it might not even be fixable if the damage is too bad.
My phone was bought it from middle east and now iam in Euorpe, If i fix euorpen part in middle east Iphone , it work or no as it must be middle east too???
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 650
Where does it get very hot? Is it at the top right of the phone? You can check this from touching the back metal housing of the phone. Sounds like a power management chip has gone bad.
Ben 의
Hallo
I did change P M and the battery but still not working
Please note my Iphone bought from Dubai and they told me that parts for Europ is diffrent .. Is that correct??
But the P B i did change also for middle east // I have spare Iphone///
For your advice
Imadeddin Sukkarieh 의
Hallo
I just confirmed with my brother, the heat started 1 cm under the back camera then it became tooooo much hot then it hearted him realy cus of high heat
My phone was bought it from middle east and now iam in Euorpe, If i fix euorpen part in middle east Iphone , it work or no as it must be middle east only ??
