주요 콘텐츠로 건너뛰기
모델 A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 질문 전체 보기
Graphics card upgrade on 27" iMac 2011?
Does anyone know what the next upgrade is of Graphics card? Currently running on AMD Radeon HD 6970M 1024MB
Apple have already done the free upgrade for faulty graphics cards but they can only upgrade to the same graphics card so i now have the same issue again.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 4개
가장 유용한 답변
Most of those boards just needed a simple reflow. I use an inexpensive ($70.00), 898D+ 2in1 SMD Rework Station Soldering Hot Air Welder ESD Tips BGA Nozzles KIT.
Then here's a short course on micro-soldering on this link for the high dollar one.. Hakko Microsoldering Starter Bundle
Hakko Microsoldering Starter Bundle 이미지
상품
$799.99
해당 답변은 도움이 되었습니까?
점수 4
댓글 1개:
BTW That's this GPU, with the recall, right:https://support.apple.com/en-us/HT203787
댓글 달기
Sadly, there is no higher graphics board for this series.
How long ago did you get the graphics board replaced? I would go back to the Apple Store with repair slip in hand. See if they can replace it again.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
If your so willing, most nvidia mxm cards will work with the web driver... take a look at this.... https://www.ifixit.com/Story/18646/Succe...
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
This thread is a bit old but since it showed up on my Google search as I'm thinking about the same thing, here it is a link that might be better than using a non-supported card:
https://forums.macrumors.com/threads/201...
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
lucy 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 7
전체 시간: 13,764
