주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
Home Button flex damaged
Was attempting my first screen replacement on a iphone 6s, using the ifixit guide and video (and ifixit parts). This screen was extremely shattered but still functional. During screen removal, it basically came off in multiple jagged pieces and I damaged the flex for the home button from not being familiar with the parts.
Researched the issue and got all the bad news. Well, the owner doesn't use fingerprint and I read that Apple fixed the update issue so I shouldn't get a bricked phone on the next update. I ordered a new home button. installed it. But it doesn't work. Completely unresponsive.
The new LCD from ifixit works 100%. I pulled screen out about 4 times and kept double checking the connection, the cable, the button. Everything looks fine, but no response when trying to use home button. I am trying to get the button replaced in case it was bad. In the meantime I turned on the virtual button.
Anyone have tips on replacing the home button (aside from the known fingerprint issue)?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
If the new home button doesn't work as well then the long home button extension cable is probably faulty.
Oh.. It looks like they have basically made the home button extension cable and the LCD backlight one piece, this wasn't the case for the iPhone 6 but unfortunately it is for iPhone 6S. I think you should contact iFixit about the screen because that home button extension cable part comes with the LCD which I think is faulty.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Yes it is all in one. That was one of my major concerns, possibly the cable inside the new display. I will email them and see if they will consider replacing by shipping me a new display in advance, since the phone is in use. Thank you for the opinion.
댓글 달기
귀하의 답변을 추가하세요
Rodney L 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 151
