Key wont spring to accessorie from the start position.
OK so I replaced my steering column in my 1991 Chevy 1500 2wd replaced the turn signal switch and wiper switch even tightened up the the loose tilt pivot point as I got to reassembling it I tested my new tumbler and it won't go back to accessorie so I pulled it back apart and reassembled it to no avail what could be the issue and where should I start? (I'm sure if I had more light I could have figured it out but it was getting dark and it's got me puzzled) thank you for reading this and thank you in advance for your help
좋은 질문 입니까?
I believe it is a spring inside the lock cylinder that probably came loose. I've heard of this happening rarely, never encountered it however. I'm not sure if you can dissasemble it but if so i haven't had any luck finding the spring only. Probably get a set of them to just bypass te hassle. 2 doors, the column and a set of keys. Test them first.
m3rciless 의
