주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
How to close the iPhone 6 properly
When replacing an iPhone 6 screen i have the following thing that botters me.
The iPhone on which i replaced the screen has a little 'space on the upper left side (on the height of the volume buttons) when its dark you see a little light. also if i push a little harder the screen goes a tiny bit down.
Question: Does this have to do with the way i click the screen in the phone?
Instruction video A shows: you have to click from top to bottom
instructoin vido B shows: once you placed it on the top, first click the bottem in and them slowly click the screen in upwards....
any advice?
Thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
The iPhone 6 Frames are very prone to bending and warping which prevents the screen from sitting correctly, I have had this issue with the screen being raised slightly above the volume buttons a couple of times and a new frame has always resolved the issue.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Yes, after all this time I found this is the best solution. (Also bending the frame back, with the right equipment ofcourse, is a good solution to a slightly bent phone
댓글 달기
가장 유용한 답변
Slide the top part in (so that the frame is under the outer frame of the phone), and then work your way down from there until the phone sits flush on all edges. Press hard and firm as it's not the easiest thing to get in there. Good luck bro!
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
귀하의 답변을 추가하세요
Alex 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 3
전체 시간: 114
