주요 콘텐츠로 건너뛰기
Released in March 2011, this lens is the successor to the Canon EF-S 18-55mm which was released 4 years prior.
Canon 18-55mm lens troubleshooting
Hello!
I get an "error 99" when I take pictures with my Canon 18-55mm lens (on a Canon D400).
I did some troubleshooting and battery, memory card and shutter seem to work just great. I assume the lens is the one at fault.
I noticed that I can successfully take shoots if I set the zoom between 35-55mm, whereas I get "error 99" if I zoom at 18-35mm. Switching between auto and manual focus doesn't seem to make much of a difference. Same for the aperture, blades open and close nicely and they don't seem to influence the lens problem.
Do you have an opinion about this? What do you think is the problem?
I can't find online anyone who had the same issue. I would like to get an idea, possibly buy spare parts I need to replace before I take the lens apart.
Thanks!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
If it's the 400D kit lens your dealing with (EF-S 18-55 II) the problem is most likely with the aperture unit flex cable. The aperture unit will become (partially) unresponsive in part of the zoom range.
Put the camera in Av or M mode and set the aperture at 3.5 (i.e. wide open), check if the problems presents.
If it does not, but the problem reappears as soon as you set a smaller aperture, you know the aperture unit is indeed the culprit.
If you can get a spare (you'd probably need to replace the entire aperture unit) replacing it is relatively easy, the unit can be taken out after removing the front assembly with a pin spanner (that's what the two small holes in the front bezel are for) and of course you have to take the rear cover off to detach the flex from its connector.
Note, if the aperture unit costs more than $30 or so, just buy the entire lens second hand on ebay, since $30 is about the going rate for this model in decent condition. Or you might want to upgrade: the latest iteration of Canon's 18-55 kit lens, the IS STM, eats all the older versions for breakfast and can be had at about 80...90US$.
이 답변이 도움이 되었나요?
점수 5
댓글 1개:
Thanks very much!!
댓글 달기
답변을 추가하세요
Luke 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 45
전체 시간: 4,563
