주요 콘텐츠로 건너뛰기
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
456 질문 전체 보기
My D-pad is stuck in down position
hello everybody ! As i say in the title my down button is stuck, i lifted the tape and cleaned carefully with alcohol like someone said in an other topic. But the problem still there :/ you have any idea about what i could do ?
Thanks !
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
Sounds like you either have something wedges in there, forcing it down OR the rubber membrane between the button and PCB may have been ruined (one way or another). If you have the time and patience, take it apart and inspect that light gray rubber piece. You may end up finding that the membrane has torn a bit. If it's torn, you'll need a replacement part to keep it in the upwards position.
Just give it a good inspection to ensure no debris is in there and that the rubber part is still intact. If those are fine, look over the portion of the PCB that'll deal with the d-pad area and see if anything looks damaged there. Follow this guide to get you on your way. Nintendo 3DS Motherboard Replacement
Update
After the added comment/answer, I did some digging around to find the sticker/metal portion discussed by the poster. I believe this is the item you're talking about, correct? Image of metal buttons attached to PCB. If that is the case, then you'll want to go to the website AliExpress and search for "3DS Direction Key Button Electrostatic Films Set". It's in there, you may need to do a bit more searching if you don't find the linked image right away.
From what you've said with the added information, it sounds like the metal portion has been destroyed and no longer pushing back up. If that's the case, you'll need to order a new one and replace it that way.
I hope this helps solve your problem!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
The 3ds is completely taken apart, i lifted the tape with the aluminium button under it and cleaned it up so there is nothing in there :/ when i bought this console it had some corrosion on the upper screen connection causes by water and short circuit i guess. Now i replaced the damaged screen and it work ...but d-pad ils still hold down. Dead motherboard ? :/
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Hi Yanndebets, I've updated my answer, please see the updated portion for more information and possible help. Thanks!
댓글 달기
귀하의 답변을 추가하세요
yanndebets 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 22
전체 시간: 1,994
