주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
iPhone 5s Home button mainboard problem waterdamage
Hi I have iphone 5s after waterdamage with new battery. Everything is ok except home button, touch id works. After dock and button replacement home button is still not working. Old home button works with another 5s. Where is home button chip on 5s motherboard? What can be damaged?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
선택된 답변
I found answer. It was FL65 chip on motherboard. Its destroyed by previous owner when removing battery. Its motherboard and need jumper. I will sell this phone asap.
Fotohttp://postimg.org/image/3t5q2nybx/full/
해당 답변은 도움이 되었습니까?
점수 0
댓글 4개:
Only thing can be damaged if the phone works is connector of home button or the pins of it. I recommend you to get a dry clean solution and clean the pins and connector of the home button. If it won't fix it, stop by at any pc repair store that has equipment for the water damaging.
Dock motherboard connector is like new, dock is from another iphone and home button 100% ok. Still I have only touch id or nothing with another button. Where is home button ic on motherboard? I have brush and iso alcohol
You just need to do couple hard reset to get the Touch ID back !!!
its a common issue for techs. I don't believe you have any hardware issues.
I'm sorry my diognistic is totally wrong give me a minute.
댓글 달기
clean this pin and take your time with it. One or couple pins are not working. I'm pretty sure about it
해당 답변은 도움이 되었습니까?
점수 0
댓글 4개:
I have new dock and new home button, I replaced this part you posted and still home button not working. This is something with motherboard?
I don't think it's motherboard if the phone is functioning without home button. It's a connection issue between home button and the motherboard. I would question the dock and the home button.
I have tested 3x home buttons and back housing with original dock from another iphone. Still nothing. I have only touch id with original button (but without button feature). Any ideas?
I have tried third home button from ebay and still nothing. It can be something with bad static or screws? Can anybody help?
댓글 달기
The touch ID home button connects to the board via CHARGE PORT assembly. I would attempt replacement of the charge port assembly, BUT spending a little bit more for a charge port assembly can go a long way. You will have a new port, therefore if it is of higher quality it will feel more normal when plugging in the lightning cable.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Krawi 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 2,509
