주요 콘텐츠로 건너뛰기
A 5-inch Android smartphone, powered by MediaTek MT6592M paired with 1 GB RAM. Not to be confused with the Doogee Valencia2 Y100 Pro.
6 질문 전체 보기
My Valencia2 Y100 smartphone screen broke
My Doogee Valencia2 Y100 screen broke and don't seem find a replacement for it.
What I did find is a screen for a Valencia2 Y100 Pro. Will this screen fit my phone? And if anyone knows where to find one please let me know as I'm not sure if Valencia2 Y100 and Valencia2 Y100 Pro are interchangeable.
When I look at the phone's model no. it says Valencia2 Y100 without the Pro at the end.
Thank you in advance.
Update (07/18/2016)
Thanks Jack.
Another question please.
But is the Doogee2_y100 Pro not the (Doogee2_y100 Plus), also Compatible for my Doogee2_y100?
Thanks again for your response.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
Hi
The Y100 and Y100 PLUS is common lcd screen, it is better you can buy the lcd screen assemble and it is better you can have experenice for phone disassemble and assemble.
Thanks
Jack.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks Jack you were very helpful.
댓글 달기
가장 유용한 답변
I found one source for the part: Doogee Y100 LCD Display+Touch Screen Original Digitizer Glass Panel For DOOGEE Valencia 2 Y100 1280X720 Phone.
I can't speak about the seller here so do be careful! Good Luck
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Thanks Dan. Very helpful
댓글 달기
en la pagina aliexpress puedes conseguir el reemplazo,http://www.aliexpress.com/item/Doogee-Y1....
espero sea util., saludos
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks Sergio Villanueva
댓글 달기
귀하의 답변을 추가하세요
ronloveflying 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 10
전체 시간: 572
