주요 콘텐츠로 건너뛰기
2014년 10월에 출시되었습니다. 이 모델 SM-G530H/DV Samsung Galaxy Grand Prime은 화이트, 그레이, 또는 골드 케이스로 제공됩니다.
How can I remove FRP lock from my Samsung mobaile?
I was hard reset my Samsung mobile ( GRAND PRIME (SM-G531H) ). Now I can't set up my device without entering the e-mail previously synced with this device. I didn't remember my old e-mail. so how can i unlock my device from FRP lock..?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 53
댓글 24개
Fortunately there are many ways to get rid of this issue. There is a complete method to UNLOCK FRP from Samsung Galaxy Grand Prime. You should give it a try, I'm sure this will help you.
That's not true. If the phone is already locked it is more difficult because the GP does not support OTG.
Wats the easiest way to remove a from lock on a S5 I bought and can't use plz help
along with many others i can get into a phone now because google has me lock out ...what control are they goin to want next its my phone i should be able to use it please help
i can remove this for you contact me on skpe "spotthemall"
댓글 19개 더보기
댓글 달기
답변 11개
가장 유용한 답변
There are few methods available which can help you to Remove frp
Steps to remove frp using OTG cable:-
you can use OTG cable and place APK file in pendrive
then connect the OTG to phone
USB storage will appear
Install the APK file
and open it you will be in Setting
then click on Backup & Reset ->Factory data reset->Reset device-> delete All
or if this method fails or you does not own OTG cable, try another method
Samsung FRP unlock without OTG cable
이 답변이 도움이 되었나요?
점수 6
댓글 1개:
this metod power on all phones , read
https://frpbypass-gsm.blogspot.com
댓글 달기
Samsung FRP Unlock All Models All Security Patch guide here.
https://unlockerplus.com/all-samsung-frp...
이 답변이 도움이 되었나요?
점수 4
댓글 1개:
Yes this service can unlock any Samsung FRP lock device even Samsung Note 20 FRP Unlock as well.
댓글 달기
look at this tutorial
remove frp lock samsung 2016 100% tested
https://www.youtube.com/watch?v=YPFAJQZ1...
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
Don't work all the time
댓글 달기
It is siple to remove if ur device locked!
Open device in lockscreen than make an picture after go in cameramode to galeri and try to send the picture example via email. Perhaps u cant send and devive will redirect you to securety options than disable cloude and wola ur device is open ;)
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
댓글 달기
You must download a aol app to remove it and will cost 20 dollars
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
댓글 달기
This one will probably work https://drive.google.com/file/d/0B3goqmz...
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
not working link
댓글 달기
https://youtu.be/oyyGseKMbq8
이 답변이 도움이 되었나요?
점수 0
댓글 달기
frp lock remove please help me my phone g361f samsung
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
댓글 달기
I have been looking for the same issue to remove FRP Lock from my Samsung Galaxy S7 Edge and I had found '''Samsung FRP Unlock Tool''', which has helped me to remove FRP Lock very easily. You need to be a bit technical.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Check here to know the all Latest Samsung Devices FRP Bypass problems-https://www.gadgetsdr.com/category/samsu...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Click here to find a complete solution to your problem ++https://minitipsx.com/samsung-account-lo...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
dilshankavindu 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 30
지난 30일: 117
전체 시간: 86,349
