주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2396 질문 전체 보기
Unknown Rubber Piece from Teardown
When removing the Logic Board this rubber piece fell out and I have no clue where this piece belongs to. By the shape of it it appears to slip onto somewhere. Anyone know where this piece belongs?
http://img684.imageshack.us/img684/3851/...
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 18개
가장 유용한 답변
it was at the top of the logic board, where the L shape begins
해당 답변은 도움이 되었습니까?
점수 5
댓글 달기
Sure....
http://img263.imageshack.us/img263/8572/...
This shows the piece installed.
Just fit it over the logic board. Its in the red rectrangle.
AJB
해당 답변은 도움이 되었습니까?
점수 4
댓글 1개:
Can you repost the photo?
댓글 달기
It's not necessary for the function if the phone. It's simply to protect the screens cables from the edge of the phones logic board. A small piece of electrical tape over the edge would work just as good...
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
Is there a place where I could purchase that black piece? When I disassembled my phone, I saw some black piece fly out and I thought it was something else, so I didn't worry about it. Now I can't find the piece...
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
here where the black rubber piece speaker of iphone 4s goes!
Where and how iPhone 4S rubber square piece speaker dropped goes
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
No that peice isnt the same as the pic he showed ive just stripped mine and it goes at the top where the barcode is to stop cables rubbing
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I have taken the phone apart a couple of times and have not come across this part. It looks like it is maybe a structural piece that goes along the inner frame of the mid body. Chances are your phone is probably just fine without it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have the same here, small rectangular black rubber. does your iphone works perfectly ?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
i have the same thing here too and don't know what to do with that piece. seems to have come out when i took out the speaker section.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Memed is correct - that piece of rubber protects the ribbon cables from edge of the logic boardso they dont crack.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Thanks Anthony...is there a way you could illustrate how to install it?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Thanks!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Peculiar, I've taken my iPhone 4 apart with the utmost care and have not ever noticed that little rubber piece. Wonders if mine is there at all. -Shrug- my two cents.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
this part is out of my iphone 4. i don't think it has anything to do with my iphone not being able to find any service though.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Haha.. Thank goodness I wasn't the only one. Googling "iPhone 4 lit" predicts "little piece" which I found more than amusing. Truthfully I didn't think I would find an answer but sure enough, right back at iFixit. Thanks so much for the photo Anthony. Much help..
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
i threw mine out because i had no idea where it came from ,now i keep loosing signal ???
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
It seems like not all of the phones have this part i did one today and it was not there and im very careful about being sure that i dont lose this part.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Took my phone apart last night and this piece fell out. I reassembled without it, and now the screen doesn't work at all. Any chance this could be responsible? I know the phone is on because it vibrates when plugged in, and the voice command works, but nothing on the screen shows up.
I'm going to take it apart again and check for breaks in the LCD cable and put this piece back in. We'll see...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
richardtong 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 37,854
