주요 콘텐츠로 건너뛰기
The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
60 질문 전체 보기
Mother Board ASUS X550L
I have a Asus X550L which is not functioning anymore due to short circuit as what the technician said, the problem was its on board power chip which they said they have to replace the entire mother board which is cost a lot.
so does anyone can share a diagram of this or anyone knows the exact details on that
power chip because now a days Im sure we can search or order it online..
please help thanks..
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi Sheldon,
This link shows the input unit of a laptop motherboard (DC jacket, capacitor, etc.). It might help you to localize where the power IC is on your motherboard.
There might be a diagram available for your laptop here. However, you also need to have the program to view the file.
I hope this helps.
Steffen
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
thanks ill go look for a program to open the file..
댓글 달기
귀하의 답변을 추가하세요
Sheldon Semblante 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 7
전체 시간: 1,705
