주요 콘텐츠로 건너뛰기
How unlock Sony Vaio BIOS
Hi. I have a notebook Sony Vaio pcg-91311l (vpcej14fx). The user set password on BIOS and forgot it. How can I reset it?
I have tried:
1. Take away the battery for 30 minutes.
2. Sony support want the documents which doesn't present
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
@s0rt3r To reset the bios on most sony vaios you need to disconnect the cmos battery . You need to tear the machine down to the motherboard and locate the battery its usually green and looks like to small round batteries taped together kinda like a figure 8 theres a lead coming off the battery that needs to be disconnected black and red wires. After disconnecting do a static discharge to remove any residual power that could still be in the board . Remove the battery and any power which you should have done before starting then hold down the power button for 60 seconds. I like to leave the computer sit for an hour or two before putting it back together reconnect the bios battery and reassemble the computer. This should fix your bios problem
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
For Sony laptops is only one way to remove password, you need to have otp pasword,
which u can generate on this website: https://biosbypass.com/remove-sony-vaio-...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Vardan Hovsepyan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 2,533
